Uglybaby Posted June 5, 2013 Report Share Posted June 5, 2013 We have a chimney that is covered in vinyl siding. We are wanting to change it to brick veneer using Tru Brix. However, we are unsure if our chimney can support the approx. 11 lbs per sq ft weight. How can I tell if my chimney will support that? Quote Link to comment Share on other sites More sharing options...
John Kogel Posted June 6, 2013 Report Share Posted June 6, 2013 Since nobody has responded yet, I will jump in. We can't answer the question. We don't know what is behind the vinyl and we don't know where the chimney is located in relationship to the earth. Quote Link to comment Share on other sites More sharing options...
Brandon Whitmore Posted June 7, 2013 Report Share Posted June 7, 2013 If it's a newer house w/ vinyl siding, it's probably a wood chase chimney. And the cheap answer is no if that's the case. Quote Link to comment Share on other sites More sharing options...
