MMustola Posted October 29, 2007 Report Share Posted October 29, 2007 I think the more interesting debate here is weather to call out something as needing repair or a maintenance item. How many of you classify problems this way? Lets look another example. If you found balusters that were 8 inches apart but met the code when the house was built, would you call that a maintenance/upgrade issue? Or would you recommend the the problem be corrected? How do you draw the line between items that should reported as recommend repair or update if you desire? I believe if the problem is worth mentioning you should be recommending that the item be repaired. Quote Link to comment Share on other sites More sharing options...
charlieb Posted October 30, 2007 Report Share Posted October 30, 2007 you should be recommending that the item be repaired Changing this condition to meet current safety guidelines will give your family a safer home. Quote Link to comment Share on other sites More sharing options...
