fqp25
    475
Everything posted by fqp25
  1. Bob, That flux on the left (Type K Pipe) could possibly be splatter from when the plumber (or whoever) soldered/wiped. Frank
  2. Instead of trying to stick the Clamp Meter inside a panel, I would purchase an AC Line Separator (I Think That's What They Are Called). You simply plug the separator into the outlet and it will separate the hot & neutral. Then you'll get an amp reading between the outlet & appliance instead of trying to spread the wires inside of a panel. (Especially those panels which look like a spaghetti factory)
  3. Thank again Mike. Nope, no seismic strapping required here. (Except for manufactured homes)
  4. Mike, Could you E-Mail me the article. I am a member, but can't seem to find that article. Thanks, Frank
  5. Back on Feb 1, 07 there was a thread named HOT HOT WATER HEATER. There was a water heater which had big scorch marks around the tank drain. J Katen also posted a similar picture of effects of a collapsed baffle. Today I saw scorch marks around the TPR valve of a 17 year old AO Smith WH. The area around the drain did not have any marks. Could this also be a collapsed baffle? Image Insert: 123.55 KB Image Insert: 93.38 KB
  6. Saw this today, 17 year old house. Mortar joints appear to be leaking moisture. For some reason I had always thought moisture would seep in through the block first instead of the joint. (Thinking the mortar would be more dense). The client (the buyer) was present during the inspection and had asked what could be done to stop this. Any help is greatly appreciated... Image Insert: 111.52 KB
  7. fqp25
    How Hot?
    Kurt, A while ago (2001-2002), we were doing an addition/remodel in Evanston. Joe Woods a plumbing inspector up there at the time had told me, that 115 max for a bathroom, and 120 for a kitchen. I did find in the 2003 Illinois Plumbing Code: Public Lavatories - Max Setting 110 degrees Shower & Shower bath Combinations - 115 degrees max Water heaters used for space heating - Must have a Thermostatic Mixing Vavle to prevent temps exceeding 120 degrees. Frank
  8. Thanks Gary, & Everybody. The client just called me, and said he went out there and could see & feel the (possible)nail heads. He agrees there is something fishy with that particular window. He wants to remove a portion of siding. I asked him to keep me informed. It's not that far from my house so maybe when this happens I can shoot out there and see exactly what this is.
  9. EIFS - Nope, not in this development. Crap on Crap. (Starting with the once fertile farmland which they ripped all the good topsoil off and filled with Crap) Katon is right, but it's business... If I had a choice I would rather inspect the cool stuff.
  10. No, there is definitely something in back of the siding. I'm 99% sure it is a nail popping out. My pictures aren't the best unfortunately. (I don't have the technology to create a hologram) My main concern is if the nails are for the window. I couldn't find any manufacturer's stamp or name on any of the windows, but I'm sure they are on the lower end. As of now I'm just going to report: further investigation...
  11. The house is less than 2 years old. Found a few rigid spots under the siding around one window. First thought is nails popping out. Possibly around some nailing flange for the window (If there is one) If so; could this be caused by the sloppy window installation? It seemed to be isolated to the area around this window. Download Attachment: fqp9.JPG 91.71 KB Download Attachment: fqp8.JPG 83.81 KB Couldn't get a real good picture.
  12. Warranty Inspection, noticed missing pieces of the stone veneer right by the roof. There is a fascia strip, but I don't think it provides enough protection. The Tyvek is exposed. Should the builder (or somebody) try to cut a piece of stone to fit, or can they get away with sealing this up somehow? Does anybody think the fascia provides adequate protection? (It is aluminum and very flexible) Download Attachment: fqp1.JPG 92.49 KB Download Attachment: fqp2.JPG 117.73 KB
  13. [ Download Attachment: Binoculars.jpg 42.05 KB Are those somebody's reading glasses??[:-slaphap
  14. Is that a "crap-trap"?
  15. 11-Bravo Infantry 7th ID Fort Ord California 1989 thru 1992 101st Infantry, Fort Cambell KY 1992 Optioned out in 1992(Military Cut-Backs) used GI Bill to go to school, finished tour in reserve. To all Vets - THANK YOU!!! Frank
  16. Bryan, I am literally spitting distance from Savoy. You might want to check with the electrical inspector of the Village of Savoy, he told me recently that they do require AFCI's. They go by the 2002 NEC and really have no amendments or changes. His name is Rex (don't know his last name) Village of Savoy Municipal Building - (217)359-5894 or his cell (217) 202-5716 Hope this helps, Frank
  17. I can't remember who or when, but somebody told me a long time ago, or maybe I read it somewhere, about having the slider to the exterior, to help form a better seal when the wind would blow against it. I don't know of any regulation, but I think this method of installation could qualify for a pro... -Frank
  18. Chris, You should wait until May 2. The fourth quarter starts then, and the payment is only $153.75 ($73.75 + $80 application fee). Before then, it is $227.50. I am planning on joining up then. Wait 2 weeks save some ca$h, why not?
  19. Just took a look at an installation manual for an AO Smith Electric Residential Water Heater, and they ask for 4" for servicing parts such as thermostats, drain valves and relief valves. Was there a floor drain in this closet? Or did you notice the water heater at least sitting in a pan? Being in Chicago or surrounding area, I bet the electrical connection was at least BX if not EMT, so unless the connectors were loose I wouldn't worry about some mothballs banging up against it.
  20. I started out just less than a year ago, and I use to print them up, and use a pretty little binder, and a couple times even Fed-Ex them. But now I just shoot to them the report electronically. Usually the clients are a married couple and and have multiple addresses, so I'll send a copy to each e-mail address, and then they could forward it to their agent or whoever they want. There have been a couple of occasions where the client is moving or doesn't have internet access, for one reason or another, then I send them a hard copy, or even deliver it in person.
  21. fqp25
    Gary, State of Mind? That could be dangerous...[:-crazy]
  22. I like that back drop of those mountains. That's real beautiful country out there, sure beats the flat lands out here.
  23. Sometimes I drop the screws even with the magnetic tips and holders. I need a real powerful electro-magnet. Ah Heck, the other day I even dropped my telescopic magnet behind a washer, trying to retrieve a screw, and my screw diver. I did mention clearance in front of the panel in my report after that. Ol' Butterfingers that day...
  24. Relax Bob, I do believe it's just a ratcheting screwdriver, or maybe we both are in the same boat. I have a Black & Decker about 5 years old. It holds a charge, because I hardly use it. I use a regular screwdriver when I take off a panel. I been doing it for years and have no complaints. The way I figure it, either way I'll most likely drop a screw or 2, no matter what I use.
  25. Extension Cord? That's Romex just hanging there. There is a piece of plastic flex tubing around a portion of it, so somebody had tried to protect it from something. The white cable in the center of the picture is a communication line just dangling there. Many problems with the wiring... That hole strap is from former plumbing, most likely the original pipe going into that Tee. Couldn't really figure out what it could be though.
