greyboy39 0 Posted October 3, 2017 Report Share Posted October 3, 2017 (edited) Had an inspection today with a p trap plumbed directly into the main stack serving the furnace/A/C condensation line. The house was slab on grade built this year. Anything wrong with the configuration? If so, any code cite would be greatly appreciated. Thanks Edited October 3, 2017 by greyboy39 Punctuation error Quote Link to post Share on other sites
Chad Fabry 54 Posted October 3, 2017 Report Share Posted October 3, 2017 It's an indirect drain for non-potable, clear waste water. It's ok. The air gap prevents a sewer back up from fouling the heating/ cooling equipment. The only draw back may be if the heating/ cooling system goes unused long enough for the trap water to evaporate and lose the seal. That's a stretch though. Quote Link to post Share on other sites
greyboy39 0 Posted October 3, 2017 Author Report Share Posted October 3, 2017 Thanks for the clarification Chad. I initially thought it could potentially back siphon as a result of being too near the main stack. Quote Link to post Share on other sites
Chad Fabry 54 Posted October 3, 2017 Report Share Posted October 3, 2017 32 minutes ago, greyboy39 said: Thanks for the clarification Chad. I initially thought it could potentially back siphon as a result of being too near the main stack. The air gap isn't big enough. I shouldn't have said "OK". Honestly, I thought you were asking if it was OK because it was an indirect connection. I just spent 7 or 8 horrible minutes reading the plumbing code. It's all in chapter 8 of the IPC. I'll email it to you if you want. 1 Quote Link to post Share on other sites
John Kogel 35 Posted October 4, 2017 Report Share Posted October 4, 2017 Are you saying they could bell it out, like a 2" bell on that 1 1/2 pipe would make it OK? Quote Link to post Share on other sites
Bill Kibbel 78 Posted October 4, 2017 Report Share Posted October 4, 2017 "Indirect" needs an air gap. More and more municipalities are requiring an acid neutralizer for the condensate. Does that P-trap have a long enough trap arm? 1 Quote Link to post Share on other sites
