BADAIR
    319
Everything posted by BADAIR
  1. try this and feel free to pass on to mi amigos ;~)) http://www.mim-online.org/architects/residential
  2. Nolan, you're welcome to tag along to Ft. Worth this late summer early fall and see a HCS throughout the phase progress from everything else i've seen so far with this 6K+sqft shaq it won't be anywhere close to right & proper i'm like your friend in Houston, never seen one here either
  3. elementary explanation water in vapor moves from warm toward cool think cold adult beverage on a warm summer day where is the condensate? outside of the adult beverage container i'd imagine where you're at, warm coastal=moist warm outside, dry cool=air-conditioned inside capillary transfer would deposit and dry on the interior air leakage, absence or breeches in vapor barrier might be the causative source not nice to install building materials incorrectly, argue with mother nature or try to combat physical laws
  4. http://www.idealindustries.com/media/pd ... rogram.pdf disregard if this is a duplicate post that search didn't retrieve
  5. Mike Holt presents this on demand and has a pdf download if you don't want to listen to Mike go through each slide and clearly explain all the different scenarios applicable... https://event.on24.com/eventRegistration/EventLobbyServlet?target=registration.jsp&eventid=254015&sessionid=1&key=0E0A774FB450608287811BFF6DBF8222&partnerref=ecmweb&sourcepage=register
  6. BADAIR
    Grey PVC???
    Early PVC DWV products were industrial gray. Dark gray is still being used for industrial pressure applications.
  7. This was just posted on another mb from a fellow inspector... "I had my first (and hopefully last) "incident" today. Was in the garage with the door down trying to access an attic scuttle when.... the husband returned home and hit the remote opener. I started shouting and trying to shove at the door as best I could from 10 feet up, but to no avail. Down I came. Nothing broke except my extend 'n climb. My body is pretty sore and the door railing didn't fair to well either. The ladder scraped their family van on my way down. I don't know if I'll recieve a repair bill from the family. I know I'm going to feel it in the morning as sore as I am tonight." I suggest unplugging the opener if this is ever encountered...the emergency rope didn't/wouldn't disengage
  8. Thanks Joe, been so long since I've seen one I old-timered
  9. 1921 Masonic Lodge Associated room on the other side of this was locked and screws were rusted/stuck. I didn't want to try and force it and break anything. Maybe irreplaceable Click to Enlarge 63.93 KB Click to Enlarge 49.68 KB
  10. http://www.nfpa.org/assets/files/PDF/RO ... PDraft.pdf
  11. Yes. In the fourth picture, the X 90 is definitely Masonite. - Jim Katen, Oregon I use to be able to remember things like that, THANKS!
  12. I know I've unearthed a ancient post but can anyone definitively identify this as Masonite Click to Enlarge 68.76 KB Click to Enlarge 74.24 KB Click to Enlarge 75.87 KB Click to Enlarge 72.74 KB Click to Enlarge 40.47 KB
  13. Part 1[utube] " type="application/x-shockwave-flash" wmode="transparent" width="425" height="344"> Part 2[utube] " type="application/x-shockwave-flash" wmode="transparent" width="425" height="344">
  14. and more from one of the local mentors Emmanuel J. Scanlan! Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! http://www.ecodes.biz/list_sub.cfm?m_cat_id=36 http://www.municode.com/
  15. To all of my TIJ family, My friend, esteemed colleague and the resident stucco expert, on many message boards, Carl Brown (aka Stucco Man) found these links and wanted to pass them on to every inspector in the universe. We thought these links may be of use and an early present for all http://bulk.resource.org/codes.gov http://public.resource.org/bsc.ca.gov/index.html Carl has over 20 years of installation and oversight experience and resides in Johnson County, Kansas. He also contributes on many other message boards and moderates @ http://www.badstucco.com/ & http://www.your-leaking-house.com/ As for me I hope all are well during our changing times and have a blessed, happy and safe holiday season. Let's all live long and prosper!
  16. Not trying to change anyone's mind or opinion but I'll be testing them until they pry my corpse off the toggle this isn't a difficult test/examination 1 confirm properly plumbed cut off valve presence, TPRV, drain line and termination 2 spin toggle any resistance call qualified plumber to replace $10-$20 valve because it failed under testing if 2 was completed successfully without resistance 3 lift toggle allow to re-seat if no discharge occurs or drainage persists call qualified plumber to clear drain line and/or replace $10-$20 valve because it failed under testing Manufacturers recommend homeowners test yearly and qualified inspections occur every 3 years This is what can happen from a malfunction or improper installation, evidence is still being collected, please click link and read the story for further information http://www.azfamily.com/news/homepageto ... 75254.html Photos are from my friendly AZ inspector Dale Duffy view and use at your own discretion Image Insert: 119.55 KB Image Insert: 128.33 KB Image Insert: 120.62 KB Image Insert: 113.28 KB Image Insert: 125.83 KB Image Insert: 126.11 KB
  17. Esteemed colleague John Cahill brought this to my attention http://www.wfaa.com/video/index.html?nvid=268648
  18. More then any of us will probably need to know but a great reference tool Downloads are large files, you can also order hard copies and CD http://www.regoproducts.com/Information/Literature.htm
  19. Charlie, No attorney here, but I'd leave the ladder as is until you decide if further action/litigation is required...been there done that, halo, screws, pins, still 1/2" shorter on the shattered left limb and 20 some odd years later wish the lawyers and I'd held out for more. The only good that came of mine, was reimbursed lost income, a Harley and I can tell you when the weather is going to change long before the 5 o'clock news AM or PM, I also know how many days in advance. Hope all who are in the process of reconstruction heal soon and heal well. all others...work safe
  20. 15.5' X&C Sears til 05-02-08 $249 +SH Target $249 +SH http://www.getladder.com/785P.cfm
  21. Mike, Our heartfelt thanks to you and all at or on TIJ for the support you have shown the Hurst families and me by getting this information out to our members and others. I can't express how grateful the families are for the Inspector community and this show of support in their time of need.
  22. AFPA/IRC/ICC Deck Design Manual - Prescriptive Residential Deck Construction Guide based on the 2006 International Residential Code from the American Forest & Paper Association website http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
  23. Message on Poo-Pumper truck Image Insert: 48.74 KB
  24. http://news.thomasnet.com/fullstory/809016 http://www.afcisafety.org/codes.html#NEC2008 also some somewhat updated info on Aluminum wiring Download Attachment: Aluminum Wire Information.pdf 170.17 KB http://www.alumiconn.com/
