319 -
Everything posted by BADAIR
cheapest gopro unless you need more & dive housing or mask you can shoot hi-res stills in vid mode & also use for inspections after vaca...write off ;~} Carnac the Magnificent sees lots of sales just around the corner
What is White Powder from Weeps on New Brick Wall?
BADAIR replied to kaltes's topic in Exteriors Forum
hey Ken possibly prior plumbing leak this occurred during dw operation slab was sloped at edge & they tiled after the dw & cabinets were installed forming a dam to distribute water along the sill plate also seen from hydro tub leak & yard irrigation impacting wall...ymmv Download Attachment: weepleak.jpg 74?KB -
Demand From Listing Agent - What Would You Do?
BADAIR replied to dtontarski's topic in Electrical Forum
been here done this made a bet w/agent & homeowner my full inspection fee if i'm right or i'll pay electrician if i'm wrong requested ahj (electric code official) meet all onsite as well this really upset the homeowner & agent though repairs were required & yes i collected i don't write things up just for pleasure -
wall-soffit termination is the best way to install these intersecting situations http://www.wconline.com/articles/print/ ... ll-details not sure what that daubed crown trim is about other than trying to mask a bad eifs to brick transition... it's still really bad a good eifs applicator could remove the trash & add another eifs detail
why not make a mold & cast your own https://www.google.com/search?q=alginat ... =firefox-a
Detail for foundation waterproofing
BADAIR replied to MPdesign's topic in Landscaping & Site Drainage Forum
not sure what you're trying to achieve but these are decent animations of supposedly proven methods http://web.ornl.gov/sci/buildingsfounda ... n2-3.shtml handbook site link http://web.ornl.gov/sci/buildingsfounda ... /toc.shtml -
if you have some spare Uncle Sugar $s to blow before tax time received this gift from another inspector all i can say is AWESOME! http://www.amazon.com/Klarus-Exclusive- ... arus+xt+11 knocked the panties off our o-lights
Knob and Tube wiring and replacing outlet.
BADAIR replied to awfarmington's topic in Electrical Forum
Bill, always enjoy your work. not sure about this though from your link The hot and neutral wires are always separated by at least 3 inches except near a connection to a box or fixture. At these places, an additional protective woven sleeve, or was used from the last knob. did you omit loom or have something else in mind? -
Wow, that name doesn't even bring up a single result on Google. I guess there is a university near by, good idea. I actually found another forum that looks like it might be the right place for this. Thanks guys. please post a link so i/others could benefit
6 buzzard luv-shaq plenty of life left
Erby, our sincere condolences here's a few versions hope it's not to late for their need http://www.youtube.com/watch?v=4I5GOPPL-z0
roof run off occurring at these locations? appears roof run off occurred shortly after base coat was installed erosion vs incomplete/improper app imo moisture analysis would be the first course of action before any remedial work progresses
pic #3 lath installed incorrectly when they snafu the underlying plaster/stucco fundamentals expect it to telegraph through the acmv surfaces
the vinyl siding industry has specific instruction http://www.vinylsiding.org/installation/manual/ Water-Resistive Barrier Vinyl siding has always been designed as an exterior cladding, not a water-resistive barrier. Vinyl siding is designed to allow the material underneath it to breathe; therefore, it is not a watertight covering. Because of its design and application, it provides a supplemental rain screen that enhances the water-resistive barrier system by reducing the amount of water that reaches the underlying water-resistive barrier. What Is a Water-Resistive Barrier System? It is a system that includes water shedding materials and water diversion materials. Water-resistive barrier systems commonly consist of a combination of exterior cladding, flashed wall openings and penetrations, water-resistive barrier material, and sheathing. Effective water-resistive barrier systems will shed the water initially, control moisture flow by capillary and diffusion action, and minimize absorption into the wall structure. The level of water resistance required is determined by the applicable building code and structure. Best Practice: To achieve designed performance, vinyl siding must be installed over a water-resistive barrier system that includes 1) a continuous water-resistive material and 2) properly integrated flashing around all penetrations and where vinyl siding interfaces with other building products such as brick, stone, or stucco. Refer to the manufacturerââ¬â¢s instructions for specific product applications and recommendations. Whichever product(s) you decide to use as part of a water-resistive barrier system, be certain the materials meet the applicable building code by contacting the manufacturer of the water resistive barrier material(s). Always consult the applicable building code for minimum water-resistive barrier requirements in your area. Keep in mind that additional measures may provide better protection against water intrusion than the minimum requirements of the building code. & in this q&a wording it's not the inspector citing code, it's the wood sheathing mfr. industry ymmv http://www.apawood.org/level_c.cfm?cont ... ch_libmain APA Help Desk Question: Requirements for weather-resistive barriers Posted At : July 17, 2006 9:44 AM | Posted By : APA Related Categories: Plywood,Code,Walls,Residential,Siding,Help Desk,OSB Question: What are the requirements surrounding weather-resistive barriers over wood structural panel wall sheathing? Can this requirement be exempt? Answer: Until recently, building code provisions and APA recommendations allowed omission of additional weather barriers over wood structural panel sheathing, which historically were recognized as water-repellent panel sheathing. With changes to building practices and in an effort to reduce chances of moisture-related problems in wall cavities, APA revised its stance on the topic in 2001 to recommend the application of additional weather barriers in wall assemblies. Leaks through exterior wall covering systems, if prolonged, can lead to mold and structural decay. This concern led to APA's revised recommendations and building code requirements for weather barriers behind all exterior sidings ââ¬â an inexpensive insurance against potential damage. Current model building code provisions call for the use of weather-resistive barriers between exterior wall cladding (e.g., all types of siding, brick veneer, stucco) and wood structural panel wall sheathing (e.g., plywood and OSB). Weather-resistive barriers are also required behind panel siding applied direct to studs. While earlier editions of Evaluation Report NER-108 recognized APA Rated Sheathing (plywood and OSB) as water-repellent panel sheathing, as defined by the Standard Building Code and the Uniform Building Code, the July 1, 2003 edition (ICC Evaluation Service, Inc. Legacy Report NER-108) no longer included this recognition. NER-108 now states, "Sheathing shall be installed in accordance with the applicable Code provisions for wood structural panels of Sheathing Grade..." In the past, some building code provisions allowed omission of additional weather barriers over wood structural panel sheathing recognized as water-repellent panel sheathing. The International Building Code (IBC) and International Residential Code (IRC) now require some form of protective barrier over wood structural panel (plywood and OSB) applied as exterior wall sheathing: 2004 IBC Supplement Section 1404.2: "Water-resistive barrier. A minimum of one layer of No. 15 asphalt felt, complying with ASTM D 226 for Type1 felt, shall be attached to the studs or sheathing, with flashing as described in Section 1405.3, in such a manner as to provide a continuous water-resistive barrier behind the exterior wall veneer." 2004 IRC Supplement Section R703.2: "Weather-resistant sheathing paper. One layer of No. 15 asphalt felt, free from holes and breaks, complying with ASTM D 226 for Type 1 felt or other approved weather-resistive materials shall be applied over studs or sheathing of all exterior walls. â⬦" The section goes on to describe acceptable application referring to Table 703.4 and certain limited exceptions. Revisions to Table R703.4 are such that options for omitting paper provided in previous editions of Table R703.4 have been virtually eliminated. APAââ¬â¢s Build a Better Home web site provides recommendations to help ensure moisture protection. APAââ¬â¢s Build a Better Home: Walls, Form A530, addresses the proper use of weather-resistive barriers. Technical Topic APA Building Paper Recommendations for Walls, Form TT-005, provides additional information. are NC inspectors fined for or restricted from adding industry mfr. instructions or recognized basic installation standards to their report verbiage?
some spiral info http://www.salterspiralstair.com/codes.htm low clearance hang sign and hard hat in the stairway opening after a few bumps folks will realize reading comprehending & donning would be most prudent & less harmful Click to Enlarge 39.13 KB
Preservation Briefs help historic building owners
BADAIR replied to BADAIR's topic in Inspecting/Appreciating Old Homes
Doug, Hopefully a small token of payback for all I've received from you over the years. -
Mike, the main drawback i see is the black... down here they're useful for one purpose good luck plying your persuasions
NRCA search for most docs pertaining to roof covering http://www.nrca.net/search.aspx?q=hail
12 Things to Know Before Buying an Infrared Camera http://www1.flir.com/12_things_to_know? ... 5516271705 Free: Introduction to Thermography for Home Inspectors for any HI considering thermography or needing credits http://irtraining.inquisiqr3.com/catalo ... 5&cid=1721
Mike, obviously follow mfr. install specs when unavailable as a general guide Condensing units require a minimum unobstructed operation and service access space 12" minimum from all sides 18" minimum service access 24" minimum between units 60" minimum above i'm of the mind set service access should be the min. 30"x36" electricians get and usually get to call this out for disconnect access, just like your pictures! although yours don't meet these specs, i report but doubt any ever get moved yours probably won't get anywhere near as hot as what i commonly see been running all day, south-west sun exposed, 5 in the afternoon with a 120~140 degrees ambient reflecting off dark brick veneer within 6", ymmv include this for our illiterate installers Click to Enlarge 76.34?KB
plastic and air space around/between sensor are poor conductors, thus 15 min delay example: this is my stat, left outside for a few minutes and i know i don't have it set in heat mode, won't happen for 4 more months WARNING!!! not for the faint of heart pull stat and put inside a baggie set atop icepack for 2~3 minutes and good to go Click to Enlarge 21.74?KB Click to Enlarge 31.99?KB
holes appear man made Click to Enlarge 38.48?KB
guess the spiders are hard at work concerned property owner found this old post and called this morning asked if i had any further information sent him to http://www.dasma.com/default.asp i think they've update some of their tech docs since i was on there last http://www.dasma.com/pubtechdata.asp
there's your BINGO unprotected ply substrate (vertical mulch) will wick and rot they can fix wall/flashing details now or fix wall/flashing details, structure and associated moisture intrusion issues down the road ignoring the facts don't lessen the cost...
