Bryan
    192
Everything posted by Bryan
  1. It sounds like you do not have a sub-fascia? All of the PVC trim manuals i have seen all call for a sub-facia or other sub structure. We have PVC trim on our home, and i will say it does move a fair bit and has to be well secured and locations allowed for expansion, especially with a cold wearther install. Bryan
  2. You can line them up side by side in word by using a 2 column table at a select height for each row.
  3. Good afternoon. During a recent inspection of a small apartment complex the PEX water lines leaving the water heater were discolored (see photo). This was primarily on the hot side; however, the return loop line was also discolored. The installer did use copper for the connections to the water heater up to about 18", which is supposed to be the minimum. Any thoughts? FYI: the hot water was around 125 degrees. Click to Enlarge 58.13 KB
  4. Thanks Marc. Just spoke with Barry, and he is still inspecting.
  5. Anyone have a recommendation for an inspector to look at a property in San Luis Obispo, Ca?
  6. Les, I personally believe this will be the case. Our work is mainly commercial and multi family; in which I have seen failures, and in a project we are currently monitoring, they will be removing the stone form the entire first level for incorrect installation. I have some photos of a apartment complex with failures i will try to dig up and post.
  7. Water flow through the coil is one way, you will see a small water meter at the unit. RUBS (ratio utility billing system) is another, where they take the total square footage of the building, number of bedrooms, etc... and divide it back. There are lots of options for back charging the utilities.
  8. The best thing might be to reach out to the building engineer or maintenance coordinator. They are typically the one with the most knowledge of the building and systems along with keeping the system running. It sounds like a water source heat pump type system where the cooling tower is used to remove the heat load.
  9. Behind on our codes, slightly. The state is however, updating the IBC later this month; however, I do not believe they are addressing the IRC. To top it off, the City of Indianapolis does not issue Certificates of Occupancy either. You are given a card to fill out, have the various trades, or the architect , sign said card saying all work was properly completed and then you return the card to the building department.
  10. Jim, I had bought one in a hurry due to a battery clip failure in the Olympus 790SW I had been using, which was discontinued.; however, I found it to be to heavy for comfort. Past that one on to the family, and searched Ebay for the 790SW and bought 6 for about $60 a piece complete with chargers and batteries. The 790SW is Shock and Water proof, and has worked flawless for the last 4 to 5 years.
  11. If you look at the joints between foam pieces, they have not been properly offset. It also looks like they used the one fastener in the seam technique, which if memory serves correct, is not allowed.
  12. It actually looks lie tile. However, if it is a concrete like material, i would say terrazzo.
  13. Here is another that may help: R106.1.2 Manufacturer's installation instructions. Manufacturer's installation instructions, as required by this code, shall be available on the job site at the time of inspection.
  14. See if these help From the 2006 IRC: R102.1 General. Where, in any specific case, different sections of this code specify different materials, methods of construction or other requirements, the most restrictive shall govern. Where there is a conflict between a general requirement and a specific requirement, the specific requirement shall be applicable. R703.10.2 Horizontal lap siding. Lap siding shall be lapped a minimum of 1" inches (32 mm) and shall have the ends sealed with caulking, covered with an H-section joint cover, or located over a strip of flashing. Lap siding courses may be installed with the fastener heads exposed or concealed, according to approved manufacturer's' installation instructions. ( not exactly what you may be looking for; however, it does indicated per manufacture)
  15. Funny you mention that, i was on a commercial project today and saw one on these in there office and asked about it. They indicated it was there second, as they lost the first one trying to fly in high winds. Said they still have not found it, and have no idea where it end up.
  16. Have you tried reaching out to a plaster restoration company? They should be able to take your original piece, make a mold and cast new. I have never seen this personally done; however, have spoke with various contractors over the years, and monitored there progress on historic restorication projects.
  17. Any chance you have an establishing shot of the outside showing the grade?
  18. I would also be interested. Just saw the new thread on education on Facebook, and remembered water furnace brand Geo thermal units are made in Ft. Wayne Indiana.
  19. I believe there would have to be; however, I have never actually handled a fitting. Next time I see one being installed, I will look.
  20. You are correct, they are crimp on fittings and require a special, typically power actuated, crimp tool. I typically find these in multi family and more commercial settings.
  21. Anyone have an idea on the manufacture date of this EPDM, or even a manufacturer? Click to Enlarge 22.89 KB
  22. I have not seen this on residential; however, on commercial jobs they will pull the windows outward 1 1/2" with treated lumber. I have seen something similar to what you are looking for; however, i cannot seem to remember how they did the "off" course of brick. Another way would be to frame the window opening with shortened brick returns around the window and tie this frame into the remaining brick with ties.
  23. The screw and outlet are both grounded as its a three prong outlet and the entire complex is only four years old. I figure they did it this way to save a few cents on each of the 504 cord sets needed for the property.
  24. I came across this setup the other day in a student housing complex. The two cord sets provide power to the dishwasher and disposal, about half of the grounds had been clipped instead of being connected. Click to Enlarge 21.11?KB Any thought to why this type of setup would be used vs. a three prong grounding type cord set?
  25. Most storefront windows and doors have a date code. The main one's I find without a code are cheap replacements. As Nolan indicated, it is typically stamped on the aluminum channel between the glazing panels.
