Seanneedhelp Posted October 29 Report Share Posted October 29 Have a 720w 8 bar style led with 3 drivers. Woke up this morning and 3 of the 8 bars are just barely lit up while the others are running like usual, tried driver on other bars and it works fine. So assuming problem is in the 3 way harness that connects the 3 bars to 1 driver Took apart and white neutral wire has a little discoloration right where it connects to the light on all 3 bars. Any ideas? Could the neutral not getting a good connection cause the leds to just barely light up? Quote Link to comment Share on other sites More sharing options...
Marc Posted October 30 Report Share Posted October 30 14 hours ago, Seanneedhelp said: Have a 720w 8 bar style led with 3 drivers. Woke up this morning and 3 of the 8 bars are just barely lit up while the others are running like usual, tried driver on other bars and it works fine. So assuming problem is in the 3 way harness that connects the 3 bars to 1 driver Took apart and white neutral wire has a little discoloration right where it connects to the light on all 3 bars. Any ideas? Could the neutral not getting a good connection cause the leds to just barely light up? Your symptoms suggest parallel connected banks of series connected LEDs. Most common configuration is one driver for each series connected bank of LEDs, but your symptoms suggests parallel connected banks. Understanding the configuration aids diagnosis. Post a picture of the driver label. Quote Link to comment Share on other sites More sharing options...
Bill Kibbel Posted October 30 Report Share Posted October 30 Grow lights? Quote Link to comment Share on other sites More sharing options...
Marc Posted October 31 Report Share Posted October 31 (edited) 19 hours ago, Bill Kibbel said: Grow lights? If 720 watts is the LED power and not an HID or incandescent equivalent, it would translate into almost 100,000 lumens. You could fry an egg with that much light. 21,000 lumens is the biggest single LED light fixture I've ever seen. It consumes 150 watts. Edited October 31 by Marc Quote Link to comment Share on other sites More sharing options...
