Has anyone heard the term "vinylized synthetic" for roofing materials? I don't have any pics, it was a questioned asked to me. I can't recall ever hearing that term. It is a low sloped roof. "It looks like a vinyl type rolled roof that is painted to look like it has shingles". That's the description I received.
I think it really depends on where you use the phone. In my area, where I venture into rural areas quite a bit, Verizon is hands down the best as far as coverage goes. If you are near the main freeway or hanging out in downtown Seattle, AT&T etc has good coverage.
Pic was sent to me so I have no background info. Looks like a disconnect of some sort, just have not seen one like this in a residential home. I was told that there is an actual panel below this. Was told the three black circles are plastic. Is it a main pull out disconnect or...? Thanks. Click to Enlarge 23.65 KB
The unit was installed about two years after the home was built. Of course the HVAC company installed it at the shortest route possible to the furnace area. There was a shut off near the unit. And the "pad" was indeed foam with a coating. I called it for repair.
Here is an A/C unit installed around 2004. Obviously not level, but... When would you call it? I did mention it to my client and am working the report now. My initial thought is repair is needed. Click to Enlarge 56.81 KB
Sorry bout this. I am in the middle of a move and have packed my tech reference materials. I have a 1992 gas water heater installed in a bedroom closet. No makeup air being drawn from the exterior, natural venting type. Thanks
My choice would be mod-bit. Tends to have a pretty good life span and fairly easy repairs when/if needed. I would avoid shingles if it is questionable on the slope.
I always tell my clients that I cannot completely determine the amount of damage, if any, that the ants have caused. I will in severe cases recommend that a carpenter/contractor do a more intrusive investigation to determine the extent of the "activity". I once had a home with car decking flooring that had frass falling from the under-floor area and piled up on the crawl space floor, I didn't bother with a recommendation in that case. I simply told my clients that extensive and expensive repairs would be needed.
Does this composite siding have a name? Looks like some kind of press board type material with a painted finish. Has to be some kind of wood composite as there were a few soft spots. Click to Enlarge 32.6 KB
