When warm enough to run the A/C, I turn that on (or down, if already running) when I get to the home. I want the outside unit to be running when I do the home's exterior (which is where I start my home inspections). I check the tag for Age, BTU, current ratings, line insulation, etc. and of course listen to it running. When I get to the inside, I am happy the home is cooling because I look cold weather and detest hot weather. I run the A/C while I inspect the attic and most of the home. While doing so, I'll take temp measurements in several rooms, especially at a supply vent very near the blower. Before I do the last rooms on the main level, I'll turn the thermostat off. Then I finish the main level and go to the basement. I'll take the cover off so I can see the indoor coil. Then, I inspect most the basement and thin get to the furnace. This would have provided approx. 20 minutes for the unit to stabilize. Then, I go turn the furnace on, watch the unit fire, check the air filter and exhaust venting, and let it run for a while. When I get to the electrical panel, I check to see what the breaker ratings are for the A/C and see that they closely match what I saw on the compressor's tag. I complete things in the basement and go check to make sure all finished rooms are getting heat. I don't remove registers or grills. Once I am confident all finished rooms are heated, I replace set the thermostat to where I found it, unless it was on in A/C. If the seller is there, I tell them to wait 15-20 mins. before turning the A/C on again. If I find no posted service records for the HVAC system (from within the past 12 months), I recommend clean/service by a qualified HVAC tech and recommend annual clean & service to the client.
