4,346 -
Everything posted by Les
Mold Inspectors Needed
Les replied to Brandon Castle's topic in Indoor Air Quality (I.A.Q.) and Mold Forum
Michael, insertion of another link was not what I expected from you. I would suggest you tell us something about your company other than puffery. If you want to advertise, then contact Mike Brown site administrator. In the meantime, tell us something. Your audience here at TIJ is different than most inspector boards; they are typically well established knowledgeable inspectors that are difficult to bs. -
Bustmold, tell us a bit more about you and your company. -
I deleted the entire post. it was over six years old and just a link dropper.
Has anyone experienced a foul smell from your kitchen sink?
Les replied to Leann M. Bryan's topic in Plumbing Forum
Yes, it was a Mackrel and I put it into the trash.- 1 reply
- 2
Sound of water trickling inside radon vent pipe
Les replied to Mike Lamb's topic in Environmental Hazards
Please don't poke fun at the radon protocols. They are in place for the children. 🚽 -
There certainly is an intellectual side to this profession and it was not recognized for decades. At one point there were just a handful of individuals that were home inspectors and they got inundated with people joining the profession that had changed a light bulb or built a deck. It was not that long ago and many remain in the business. As I understand and recall your path, you choose complete immersion and are blessed with great ambition. You also brought an intellect and mindset that was not common at that time. Now you are an educator and mentor - but it has been a journey! We both (all) know inspectors that are off the scale with intelligence, knowledge and skill. They keep me humble and every beginning inspector should be so lucky to know one as a friend.
- 15 replies
- 2
- customer service
- report writing
(and 1 more)
Tagged with:
the bracket that holds the pressure switch sure looks field fabricated to me. it has different fasteners than the remainder of cabinet shown in photo; raw edges, fasteners, discoloration at throat of inducer, etc. the burner cycle you describe is of concern. I really can't imagine aftermarket parts not being available. Maybe things are different in Canada.
I took another look at the photo and realize I have never seen a configuration like that. I, of course, have not seen everything, but this looks like some sort of field modification. Is it original?
What Marc and Jim said and check both tubes for moisture. Pull them off on the low side while unit is idle.
The Durability of Solid Masonry Construction
Les replied to mgbinspect's topic in Inspecting/Appreciating Old Homes
That was a success! Kurt M was involved with something similar years ago. Your thought process was the key. These masonry stories always make me think of Tom the Builder from Pillars of the Earth. -
😀that makes sense. They really are authorities and certainly have lots to say! I have a little problem when an entire industry seems to think the tasks can only be accomplished in one way. For instance, some of the best reports I have ever read have no photos! However, most reports would benefit from photos that are more "meaningful" and better composed.
- 15 replies
- customer service
- report writing
(and 1 more)
Tagged with:
soffit, ridge and gable vents? past mold remediation? un-insulated kitchen vent? can't say I have ever seen that much moisture on a styrofoam baffle.
"Exterior / Roof Survey Findings: The roof, roof drainage systems, jacks, flashings, skylights, chimneys, other roof penetrations were observed within the limits of accessibility. The method of observation, which is suggestive of the extent to which the roof and related components were observed, is set forth in the components section. Wall cladding, flashing, trim, eaves and rake fascias (barge rafters), doors, windows, and garage doors were observed if present. If bedroom windows have security bars, they may be required to have release mechanisms. The release mechanisms are not tested by the inspection company. It is strongly recommended that you have the owner or agent demonstrate the release mechanism on each window. Significant visible deficiencies or potential concerns, if any, are reported below. Any visible deficiencies in abutting or attached decks may be reported in the STRUCTURE section rather than here. Visible signs of leaks or abnormal condensation (if any) on surfaces are reported in this, and/or other pertinent, sections. Exterior systems or components are indicated by type or described in the components section. [R] [M] [N] 1000: Roof repairs / general maintenance needed. Roof deck appeared to have sagging areas [P] [F] 1120.02: Cut back tree limbs to break contact with roof. See series 1120.02 photo(s) [P] [N] 1120.02: Cut back tree limbs to break contact with roof. See series 1120.02 photo(s) [R] [P] [N] 1230.04: Metal flashing faulty or otherwise amiss. Flashing not flat on roof - could allow wind to damage materials. See series 1230.04 photo(s) [D] [N] [P] [F] 1280.13: Downspout part(s) appear to be missing. See series 1280.13 photo(s) [A] [N] 1320.02: Siding buckled. Soffit on rear of home appears to have and area that is either sagging or a change in pitch. [A] 1320.03: Siding warped. Noted at the rear of the building. See series 1320.03 photo(s) [A] [F] 1530.03: Window faulty or otherwise amiss. Noted at the front entry door. Photo: 1120.02 (1) Photo: 1120.02 (2) Photo: 1230.04" little excerpt from Mike's report. I have a little confusion on what the letter and numbers are and why.
- 15 replies
- customer service
- report writing
(and 1 more)
Tagged with:
This is not one of your better pieces. I read it as a Mertz and Sipe discussion. You posited your points and then supported them via quote. I know both and have great respect for them and their opinion(s).
- 15 replies
- customer service
- report writing
(and 1 more)
Tagged with:
you have stirred my curiosity. do you have photos? inside and outside. it would not be common for that much moisture in attic, regardless.
Fried chicken!
Best served with a nice Chianti and fava beans!
kinda citrus like sweet. also when I had to mix white lead powder into linseed oil, the dust would taste sweet. "Here is a dollar. Get down to the co-op and get five pounds of white lead."
lead alone is sweet and soft
and a tan color dog?
..............or neither.
all I know is that every person that breathed air in Michigan died, eventually!
What about Ed McMahon?
I am curious about what your opinion on the test results report. Was it clear? Were there any clear convincing statements regarding what mold was present and in what amounts? I am a moderately experienced home inspector and have yet to read a consumer mold sample report that is clear. I have read some from real environmental labs that are quite good.
Wasn't there a product in the eighties called Euroboard that was a backer also.
