Phillip
    1,434
Everything posted by Phillip
  1. Have you got a shot of the whole panel?
  2. I hope you have at lest 30 more
  3. In my area they are called cut valley. I write them up if they are not cut where the greater water slope or greater pitch. I had 2 of them on the same day last week. The first one is where they repaired around the chimney. Click to Enlarge 115.78 KB Click to Enlarge 86.52 KB The other one was on a 4 year old town house. The cut was 4 inches from the center line and someone had patched on it. Click to Enlarge 110.92 KB Click to Enlarge 78.75 KB
  4. The house was a foreclosure, built in 2004
  5. This plumbing has got a little to hot. Click to Enlarge 57.1 KB Click to Enlarge 48.96 KB Click to Enlarge 42.62 KB The client is already looking for another house. He was ready to move on after I show him this. Click to Enlarge 54.63 KB Click to Enlarge 65.74 KB and this. Click to Enlarge 65.46 KB Click to Enlarge 53.72 KB
  6. Chad, I see you are inspecting crap too.[:-dev3][]
  7. On my walk and talk I look and check the same things I would if I was doing a written report. I just tell my client what I find and they write down what they want to.
  8. Ezra, That is a good dream. It seams that I lacked the willpower to cut back on my food intake and do what I need to do to lose the weight.
  9. I look at it like this way. The flashing has a proper way to be installed. It is not installed as it should be.
  10. Jim, I have seen them like that and write them up every time.
  11. There is no storm collar on the roof flashing and the shingles are installed on top of the flashing at the bottom where the bottom/lower area of the flashing should be on top of the shingles.
  12. Older roof. The flashing around the plumbing vents have busted open. Some one comes and cuts the top out of new flashing and slides them down over the old flashing. Click to Enlarge 43.83 KB Click to Enlarge 123.29 KB Click to Enlarge 96.61 KB
  13. The pipe is hard to see, but the pipe runs up out of the ground then turns down. I would say this is trap in the line. Has there ever been a time this would of been approved. The house was built in 79. The water heater is a 2000 model. Click to Enlarge 76.68 KB Here is where it runs out the wall in the lower level of the house Click to Enlarge 51.96 KB
  14. Steve, Here are a few more photo that goes along with the first photos. The water heater is in a cloths closet upstairs. Click to Enlarge 29.69 KB The shut off for the gas line is in the wall to the left of the water heater. Click to Enlarge 23.74 KB This is the vent on the roof. What do you see that wrong with this set up? Click to Enlarge 77.91 KB
  15. **** Click to Enlarge 53.16 KB Click to Enlarge 74.32 KB Click to Enlarge 49.03 KB
  16. Mine does not have the flex but its got the Goop. Click to Enlarge 35.97 KB
  17. someone comes up with these ideals? This is in the attic. Click to Enlarge 42.95 KB Click to Enlarge 40.51 KB
  18. Some of the condos I have done would have the little blower unit and coil above the tub in the bathroom. They had a metal panel that opened up where you could get to them They are a pain to install. When I get time I will see if I can find a photo.
  19. mmddyy area Alpha for which one it was for the day 032210TA T is for Tuscaloosa
  20. Ruffus: Hay Bubba these wires you stuck in here don't make it to the breaker box. Click to Enlarge 38.03 KB Bubba: Take some of them there wire connectors and make them lone enough. Click to Enlarge 44.55 KB Ruffus: Hey Bubba they want a row of lights in that there big room up front. Bubba: I done did that. Click to Enlarge 24.28 KB Bubba: I have added them a new turn on place. Click to Enlarge 33.03 KB
  21. Thanks Chad, I try to to the best I can for my clients.
  22. No that a vent. The house is five year old. It is a week end getaway. out in the county on 79 acres with lakes that covered 20 of them. It had a leaking chimney Click to Enlarge 104.34 KB Click to Enlarge 76.66 KB Click to Enlarge 23.16 KB
  23. Todays crawlspace. I don't know if the Krawler would work here. Click to Enlarge 44.23 KB Click to Enlarge 48.84 KB
  24. For carrying item into the crawlspace I use a simple hard plastic tote tray that about 6 inches deep. I side it around in front of me. I carry everything in it that I carry into the crawlspace.
  25. As I am still learning about the governance of ASHI I see this as taking thing away from the membership. I do agree that there needs to be changes made. There are some good points in the motion like a smaller board and that the directors should be open up to others beside the CoR. I would voted yes for these changes. But as a whole (motion) I voted no.
