BADAIR
    319
Everything posted by BADAIR
  1. there are numerous documented issues with afci of differing mfr i've provided all pix & descriptive documentation to their customer/tech support w/positive results https://www.eaton.com/us/en-us/support/eatoncare.html
  2. John, i have a Benjamin, says it's natural stone Adhered Manufactured Stone Veneer (AMSV) would have a stucco like base atop the osb also down here amsv is a very rare choice
  3. Marc, thanks for asking depends on what "alright" means to those observing 3 1/2 score & counting, w/no treatments or medications required, all gov required licenses & paperwork are up to date, can still own firearms legally, i'd say i'm as good as i'll ever get someone with a higher pay grade will have to verify "alright"
  4. if ur footin' it & not tla & run out...psa info We have all experienced being caught without toilet paper. It is something we dread, obviously, because recent times have shown us that toilet paper brings a sense of tremendous psychological comfort. Even the thought of being without it, renders the average person uncomfortable at best, and extremely desperate, in the worst cases. Fortunately, we have options. This article will help you navigate them. One very positive point of using leaves as toilet paper is that most plants, including the ones listed in this article contain anti-bacterial components. These leaves will help prevent infections from developing. Squeeze the leaf before you use it to release the medicinal compounds. Lamb’s Ears (Stachys Byzantina) – The ‘Charmin’ of nature’s toilet paper options Lamb’s ears tend to grow in similar areas to Mullein, arid and rocky. Although this plant can be found in northeastern climates as well. In ancient Roman times this plant was used for bandaids. Lamb’s-ear flowers in late spring and early summer. Plants produce tall spike-like stems with a few reduced leaves and small, light purple flowers. Mullein (Verbascum) – Second runner up to Lamb’s Ears for softness Mullein sightings are along roadsides and in rocky and gravel banks. It thrives in full sun and grows well in arid conditions. Mullein has a deep spindle shaped root from which a rosette of leaves rises. It has soft hairs and its leaves feel like velvet. In summer months the stalks are tall and produce long clusters of yellow buds that crown this majestic plant. The leaves can grow to three inches wide and six inches long. This makes the leaves a great substitute for toilet paper when out in the woods. Plantain (Plantago) – Unbreakable and easy to find almost all year long Plantain is a very common plant in lawns, driveways and many partly shaded wooded areas. It is known as nature’s bandaid and has remarkable wound healing attributes. Related: How to Make Anti-Inflammatory Band-Aid Using Plantain The leaves shown here can grow quite large, about half the size of a slice of bread, or even larger. Grape Leaves (Vinis Vitifera) – Used as toilet paper in ancient Greece The ancient Greeks left us with a tremendous legacy of knowledge – toilet paper alternative included. Wild grapes grow prolifically in hot sunny areas and can be found in warmer months in northern climates. Two benefits – the leaves are wide and incredibly sturdy. Cabbage or Cauliflower Leaves (Brassicas) – Wide, strong, plus very hard to break In harsh times homesteaders would use cabbage leaves as toilet paper. You can even dry them and stack them for future use. One major advantage for gardeners is ease and proximity. You’ll always have an option! Brussel sprout leaves also fall into this category. Borage (Borago Officinalis) – Use the young leaves only! Borage is also an option. Just make sure that you forage the young leaves in June and July before they become too large or prickly. You can stack the smaller leaves and make a small fan to complete the job. The purple flowers are delicate and beautiful. They make this plant easy to spot in sunny forested areas. Related: 18 Plants That Should Always Be Planted Together The flowers have long been used to bolster courage. In medieval times the flowers were embroidered on the mantles of knights and jousters to bring them courage! This plant brings many gifts: it soothes respiratory ailments, boosts adrenal function and alleviates depression. Yellow Dock (Rumex Crispus) – Very easy to spot and has large leaves Yellow dock is also a common lawn and partly shaded wooded areas plant. Notice the intricate vein structure and blood red vein running up the middle. It is a prominent feature. The leaves can grow extremely large, the size of a romaine lettuce leaf! The roots have amazing blood cleansing properties and the leaves are very sturdy, making them a prime toilet paper substitute. Common Tamarisk Moss (Thuidium Tamariscinum) – The elegant, exotic alternative When you are in the woods thick layers of moss are easy to find. Moss layers come up easily when you peel them off of a tree. It may look intimidating but do not worry, they contain tannins that are naturally antibacterial. With the green side up, if you have enough make a soft roll. In thick dense wooded areas this is a common and wonderful alternative because it is soft and has cleansing properties. Trees Have Hundreds of Leaves! Large Leaf Varieties Also Make Great Toilet Paper Substitutes Catalpa Tree Leaves Win the Prize for Size Native to warm temperate and subtropical regions of North America, the Caribbean, and East Asian trees are primarily used for lumber. The large showy flowers are white, yellowish, or purplish. Bees love them! You will spot the fruits of this tree, cylindrical pods with white tufts of hair at the end. This tree will give you an endless supply of natural toilet paper if you can find it! Coltsfoot (Tussilago Farfara) You will find Coltsfoot in shady lowland wooded areas that are often rocky. It grows from spring through early winter and the leaves can grow to the size of your hand. It is tough to break them so they are a great alternative for toilet paper. This leaf has been used since medieval times as an expectorant and is very high in zinc. Redbuds Tree (Cercis Canadensis) Soft and fuzzy to the touch, the beautiful heart-shaped leaves on this tree turn a brilliant red during the fall months. The leaves are quite thick and are larger than your hand. Related: The Most Common Edible Trees Growing In Your State The bark of the tree was used by the Native Americans to treat diarrhea. Empress Tree Leaves (Paulowmia Tomentosa) Paulownia came to the west from China where it was a highly prized variety. In the east, it was used to treat a wide variety of diseases. Tea from the leaves used to dissolve ulcers, heal bruises, revive the growth of hair and prevent greying. It is more common in warmer climates but can also grow in the north. Caught In a Snowstorm Without Toilet Paper? Pack a dense snow ball and use that for a wipe. It is not a perfect alternative but it is something that can at least buy you time plus keep your hands clean and reduce bacteria. Don’t forget to wash your hands with new snow afterwards! Now that you know some of your options don’t you feel the panic of possible toilet paper shortages fading away? The gift of nature is that it makes us confident and resourceful in all circumstances. Try some of these options, before you actually need them so that you will really be prepared.
  5. no arrangement required always fly translove airways
  6. my thoughts exactly woke multi-taskin' device everyone gets a full belly & lit kumbaya, my lord, kumbaya
  7. often seen down here known as wazwood or vertical mulch
  8. i've worked a few "elderly-child endangerment cases" thru attys, 1 published in a 3 week newspaper exposé the attys were all large & in charge types, wanted what's best for the "innocents" & knew who, what. where & when further action, beyond their office was required if your atty isn't providing assistance & direction prob need a new-better atty
  9. wet dry vents.pdf
  10. Garage Electric_202106031442279869.pdf
  11. right or wrong it's my opinion i see no difference than some of the properly sized-installed, yet maintenance neglected, decks-stairs that i've seen reported in the news causing injuries or collapsing in your & my markets i'm in a licensed state that requires me to use a promulgated form in the "preamble" of said report form is this quote in all bold caps ITEMS IDENTIFIED IN THE REPORT DO NOT OBLIGATE ANY PARTY TO MAKE REPAIRS OR TAKE OTHER ACTIONS, NOR IS THE PURCHASER REQUIRED TO REQUEST THAT THE SELLER TAKE ANY ACTION. there are no pre or post inspection police that i'm aware of like i tell folks "don't follow my lead, what i may be doing has gotten others in a world of hurt"
  12. some stats say falls are #1 cause of household accidents i clearly report the facts (you noted), advise replacement if situation warrants (i would based on your narrative of conditions present), costs be damned & let the client decide on how they want to move forward purchasing opp (other peoples problems) is an adult decision & adulting has become as rare as common sense
  13. discoloration could be anything recently had separate black brick veneer with black mortar & natural austin stone veneer with white mortar gigs that browning-yellowing all of a sudden appeared post-construction at isolated hi-mid-low areas of brick, stone, mortar materials no moisture intrusion bleed & not a thing w/vb, sheathing or from the required 1 1/2" void was found after invassive-destructive testing, bricks & stones were removed the culprit was determined to be the "slag-slop" mortar cleaning products used by the masons they're removing all affected materials...
  14. i've worked the dfw & farther markets for over 24 years municipal inspectors will allow almost anything to pass & exercise sovereign immunity, they are not consumer protection advocates, they work for a system whose main purpose is to collect more taxes, improved property brings in much more revenue than a vacant lot that being said, there was a long period where "code required" wrb were not required over exterior substrate sheathing of any type for any exterior cladding glad to see you've encountered slight moisture intrusion vs. many of the props i've inspected I don't have Text Available please call or email only Best Regards, Barry Adair Owner-Professional Inspector-Moisture Analyst-Infrared Thermographer Commercial-Residential-Construction-EIFS-Stucco-Exterior Claddings Inspections TREC Professional Inspector License # 4563 Exterior Design Institute: EIFS-MA TX # 39 Texas Infrared: Level I Certified Thermographer National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX NSPF Certified Pool Inspector CPI Operator CPO # 75-221486 ADAIR INSPECTION office: 972.487.5634 e-mail: adairinspex@hotmail.com website: http://www.adairinspection.com
  15. happened to be slumming the other day & saw this appeared similar shape does size matter? https://www.lowes.com/pd/Rinnai-Tankless-Gas-Plastic-Water-Heater-Vent-Kit/1000234039?cm_mmc=shp-_-c-_-prd-_-plb-_-google-_-pla-_-209-_-soswaterheatersparts-_-1000234039-_-0&placeholder=null&ds_rl=1286981&gclid=Cj0KCQjwiqWHBhD2ARIsAPCDzam9Oa-psDNtY36b_8PM-o0rqSrB6_vnRguhCSaSSXnIsUBnqL6bqUsaAj94EALw_wcB&gclsrc=aw.ds
  16. thought the top might be a smoked colored lens like skylights i've seen let us know if/when you find out
  17. wag: solar tube skylight what was below
  18. inspected numerous "conservatories" & canned hunt compounds with animals from all over the planet & multiple structures on-site all across tx & ok not my cup of tea but a gig is a gig & many have converted to other usage, better imo
  19. without pictures i can only hazard a guess wrench house? or did you mean ranch-house possibly bridging, blocking or strip could help: R502.7.1 Joists exceeding a nominal 2 inches by 12 inches (51 mm by 305 mm) shall be supported laterally by solid blocking, diagonal bridging (wood or metal), or a continuous 1 inch by 3 inch (25.4 mm by 76 mm) strip nailed across the bottom of joists perpendicular to joists at intervals not exceeding 8 feet (2438 mm).
  20. cockamamie stuff happen on & with the interweb 2 yr old replies, because! scifier in me relies, ghosts in the machine take your pick HAPPY NEW YEAR to all may all stay safe, healthy, happy & prosperous in the New Year we lost way too many good ones in 2020
  21. depending on the comm/res sales market in your area & gov/licensing & with your background i'd heavily market comm less agent & client bs & less emotional & spousal issues to deal with hrs entailed & $s are much better as well
  22. that took some serious 3B consideration bud & bayou brain-storming the bud could be liquid or horticultural variety ran crews in SBC in the '90s Joie de vivre
  23. i personally stay away from prescribing any retrofit-upgrade-alteration to properties i've not inspected & really have no knowledge of beyond that of the op w/o any pix numerous prospective clients actually send me pix & my standard reply is "unless i can see the current conditions in person i cannot factually comment any further, if you need someone to offsite evaluate i am not your inspector"
  24. baby steps i was just trying to exhibit to the young man, as most others had expressed, there's more to it than passing a test
