Erby
    2,795
Everything posted by Erby
  1. Let me guess Main Street Host Scam What a waste of good money!
  2. iPhone with AT&T works great for me IN MY AREA! But I note that Verizon either now does, or will soon, offer the iPhone.
  3. Mine says: (edited as necessary) The front door operates acceptably however, the door has a deadbolt that requires a key to open from the inside. How are your children going to get out in an emergency? Generally accepted nationwide safety practices call for exit doors to NOT require a key to operate to allow for emergency exiting. I recommend the installation of a deadbolt lock that has a thumb turn on the inside portion of the lock. I also recommend that you change all locks upon moving into the home. That way you are assured that no one else has a key to your house. You should also change the code on the keypad for the garage door.
  4. I can just picture Mike standing there yanking on a zipah while the stain spreads.
  5. HomeGauge here. System by System report (Though I follow walls during the inspection) 45 min to an hour for the report. Most problems input on sight. LOTS of photos (typically 100 or so) though not all go in report. Serial numbers etc are photo but not in report. Use for age determination. Camera functions as my digital notepad. Pictures and hand signs better than written notes as my handwriting sucks.
  6. Click to View The Details of the Festival 59.86 KB
  7. Thank y'all for your input. Yes, it appears that the original unit was sized for the first floor and then the basement was finished later. When asked about it by the buyer, the seller said he'd had load calculations performed when the basement was finished. When the buyer asked for a copy of them, they were nowhere to be found and the seller couldn't remember who had performed the load calculations. At last contact, the buyer was asking for load calcs to be performed and provided to the buyer. -
  8. I disagree John. It's also more likely to come loose and generate heat even with the panel cover closed.
  9. Perlite is more like Styrofoam and wouldn't crumble to powder for me. Will "expanded" perlite crumble to powder?
  10. From a friend: =============== "I found this stuff in the attic of a 75+ year old home in Louisville today. There was multiple types of insulation in the attic. This stuff looked like and was the same size of Styrofoam beads. But when I pinched a bead of the stuff it easily turned to power. It was the consistence of talcum power." Click to Enlarge 25.76 KB Click to Enlarge 43.53 KB ======================= Perlite doesn't turn to powder in my experience. Any other ideas? -
  11. It's not MY picture. It's an old one I snagged several years ago and could never find the originator of. It does address the issue.
  12. Did it look like this? Click to Enlarge 45.96 KB
  13. Any suggestions on this comment: I am concerned that the size of the heat pump may be inadequate for the size of the finished area. While I note that the only way to properly determine Heating and Air Conditioning size of unit to size of house is to do a load calculation (outside the scope of this inspection), I also note a "rule of thumb" (NOT A LOAD CALCULATION) generally indicates a range of 500-700 square foot per ton of cooling. The model numbers (Interior: WestingHouse B4VM-X60K-C & Exterior: Nordyne FT4BF-060K) indicates that this is a five ton unit. 5 x 700 = 3500 square feet. You told me the finished area was, first floor - 3122 sq.ft - basement - 2,000 sq.ft. Total finished square feet of 5,122. I recommend that you consult with a heating and air conditioning contractor to ensure that this size and efficiency of unit can handle the 5,000 plus square feet of finished area.
  14. Blower fan not working. Restriction in duct.
  15. I had full tablet functionality in XP on a Gateway a few years ago. Worked real well!
  16. And as of tomorrow, perhaps even late this evening, it's just gonna get even worse. The temperature is already above freezing and tomorrow and Saturday we're supposed to have a heat wave of over 50 degrees. All that ice is gonna melt and start soaking into stuff. For the owner's sake, I sure hope they have good homeowner's insurance. They're really gonna need it.
  17. Better off making your own "New Topic" with the name of the machine in the subject.
  18. "One man's misfortune is another man's fortune." So my car mechanic tells me every time I have to go see him.
  19. Some of the photos of it. Click to Enlarge 36.03 KB Click to Enlarge 29.93 KB Click to Enlarge 36.63 KB
  20. Yeah, cutting a piece of plywood is always easier than finding a new adjustment screw!
  21. Well Mike, you could just start your own scam to get rich too instead of working hard for it! Main Street Host's scamming black hat SEO works quickly, for awhile. Eventually it'll catch up to you and you'll drop like a rock in the rankings. There's a right way to do things and a wrong way. One of my competitors hired them and they put MY vehicle picture on his Google listing, submitted fake reviews, gave him a business address in the middle of the University of Kentucky Campus, etc. It'll catch up. Karma can be a real bitch! From wiki White hat versus black hat Main article: White or black hat SEO techniques are classified by some into two broad categories: techniques that search engines recommend as part of good design, and those techniques that search engines do not approve of and attempt to minimize the effect of, referred to as spamdexing. Some industry commentators classify these methods, and the practitioners who employ them, as either white hat SEO, or black hat SEO.[40] White hats tend to produce results that last a long time, whereas black hats anticipate that their sites will eventually be banned once the search engines discover what they are doing.[41] =============== http://main-street-host.pissedconsumer. ... 60850.html
  22. I doubt that it's Bob. Probably hired someone like "Main Street Host Scam" to do SEO for him. It's a common one running around.
  23. Sure looks more like a system that allows you to operate HARDware. -
  24. Wow, I'm surprised that AHIT didn't teach you about that, Julie. You might want to give them some feedback about it.
