I have found a few that the drain line from the tubs was leaking and where the shower pan was leaking. Like Erby said walk the outside again after running the water.
Here is where I did a little HVAC upgrade on one of the girlsââ¬â¢ house on the university here. Not as grand as Darrenââ¬â¢s project. I wish I had took photos before I started tearing out the fan coils We tore out 26 fan coils for the second and third floor. The second floor coils was above the ceiling and the third floor coils was in the attic We installed 22 new fan coils and 4 one-ton Mitsubishi Heat pumps for the sleeping porches. The 4 units work off one exterior unit. Here are some shouts of the Mitsubishi Heat pumps Click to Enlarge 81.01 KB in attic Click to Enlarge 73.02 KB Second floor sleeping porch Click to Enlarge 33.33 KB Click to Enlarge 44.45 KB We replaced the old water chiller with and new 10-ton chiller. Click to Enlarge 65.06 KB Click to Enlarge 53.2 KB What made this bad was the fan coil unit that they wanted us to use would take 8 weeks to get here so we had to order some fan coils that where larger to get them there in two weeks It is fun installing fan coil units thatââ¬â¢s 6 inches wider than the one that was there to start with above the ceiling in the hallways We had to move the control boxes to the side the coil hookup where on so we could have some room to pipe the chill water to the coils. 4 of the coils we had to mount the control boxes to the walls and had to pipe the control vales for the water away from the coils not next to them as they are installed most of the time. Here are some photos of the fan coils above the ceiling. Click to Enlarge 58.67 KB Click to Enlarge 46.93 KB Click to Enlarge 57.84 KB Click to Enlarge 51.59 KB Click to Enlarge 63.5 KB Here are some of the fan coils in the attic. Click to Enlarge 74.25 KB Click to Enlarge 69.48 KB Click to Enlarge 65.34 KB Click to Enlarge 68.46 KB Click to Enlarge 69.42 KB We also replaced an exhaust fan for the bathrooms in the attic. Click to Enlarge 66.26 KB These are shots of other items in the attic. Click to Enlarge 57.41 KB Also we added a 5 ton heat pump for added cooling in the dining and living room. It has a damper set up where they can have the unit blowing in both rooms or just one of the rooms. Click to Enlarge 44.23 KB Click to Enlarge 89.73 KB Click to Enlarge 43.03 KB The door facing had to be removed to get the unit in. In the basement we added a small Mitsubishi heat pump for the computer room. Click to Enlarge 63.12 KB Click to Enlarge 32.59 KB Click to Enlarge 34.73 KB
In some of the older homes I have done where you could tell that there had been roods there because of the voids in the dirt most of them did not have any damage from the rotten roots. A few had some damage. I guess it would depend on where the roots are and how large are the one you cannot see. I would go with what you told them to start with.
Les, It seems like you are inspecting the same type of crap I do. I would like to know how you inspect 3 homes like that in one day plus get out the report. I would be at each house 3 to 4 hours and it would take me at lest 2 or more hours to write the report. By the way I am a Bud light man, but I will try anything someone else is buying/[]
Thank you for the information. It is the first time I have seen this. I talked to some of the inspectors n my area and they had not seen either. I could not get a good view of the ends so I could not tell. There where other electrical problem so I recommend to have the electrician verify which one it was.
In the 50's did they make stranded aluminum wire or stranded tin coated copper? Click to Enlarge 78.05 KB Click to Enlarge 37.42 KB Click to Enlarge 34.37 KB
Covered with wood, Doubled taped, over fused and when they winterize the water they unhooked one of the wires to the water heater. Click to Enlarge 78.64 KB Click to Enlarge 61.86 KB
Around here there is a shut of at the meter and on newer homes there is one just outside the house you can turn off by hand if you keep the dirt out of it.
It may just be my neck of the woods, but most of the arch windows I see have a steel lintel installed. The 5 year old house had past repairs of the mortar joints and the house across the street with the same window had a lintel. The 30 year old house the bricks above the arches did not have any cracks.
I know some type of arches do not need support by a steel lintel support This week I have run into two homes that did not have visible support. I believe there should be some there. I would like to hear what the group has to say. This is from an 30 year old house and all of the front window where the same. Click to Enlarge 39.23 KB Click to Enlarge 49.05 KB This is from a 5 year old house. Click to Enlarge 48.27 KB Click to Enlarge 62.87 KB
Lets start with running a washer drain line. Click to Enlarge 87.31 KB Click to Enlarge 21.44 KB Now replaces the damaged dryer vent. Just shove the new one in the old one. Don't worry the plastic will melt off. Click to Enlarge 67.46 KB Now repair the damage hose bib on the front of the house Click to Enlarge 86.84 KB Water heater repair is next. take some tape and run it around the flex line to hold that water in. Click to Enlarge 53.64 KB tape this garden pipe to this there pipe and the tpr thinga is fixed Click to Enlarge 40.15 KB
I would like to say a big THANK YOU to each and everyone that has stood up an serve our country In the past present and those who are ready to go when called.
And there are realtors and builders around here that want to know why I call out the missing kick out. Click to Enlarge 67.21 KB Click to Enlarge 30.82 KB Click to Enlarge 46.71 KB Click to Enlarge 30.54 KB Click to Enlarge 29.81 KB
Owner installed window. say he has the molding to go around the window. Click to Enlarge 86.54 KB Click to Enlarge 61.53 KB Click to Enlarge 63.55 KB Click to Enlarge 65.76 KB
The only time I've seen Manual J calculations is when I was learning how to do them. Even if you have them done you still have to installed the duct properly. A zone system is what you need to keep 2 or more levels at the same temp.
