Chad Fabry Posted January 11, 2014 Report Share Posted January 11, 2014 We're coming down the home stretch on our home restoration project. Any of the moldings and trim that were missing, I made or had knives made to replicate the components. One skill set I don't possess is applying a plaster pattern to a wooden base like those used in picture frames, and in this case, like the picture rail in our living room. I can't re-use the picture rail- it was obliterated by layers of thick latex paint and much of the plaster was missing. I found a piece of the original rail on top of a foundation wall in the basement. It's in bad shape but a few sections are in good enough condition so you can make out the pattern. I've had zero luck finding anything on the internet- do any of you know of companies that still produce this stuff? Obviously I'd like the exact pattern, but short of that, something similar. Click to Enlarge 53.3 KB Quote Link to comment Share on other sites More sharing options...
Jim Baird Posted January 11, 2014 Report Share Posted January 11, 2014 Don't know how strict you are on restoring, but I'd substitute something I could get done. Quote Link to comment Share on other sites More sharing options...
Mark P Posted January 11, 2014 Report Share Posted January 11, 2014 I don't have an answer, unless you could have it made with a 3d printer; but if Les ever organizes a TIG road show I vote for a stop at Chad's House. Quote Link to comment Share on other sites More sharing options...
David Meiland Posted January 11, 2014 Report Share Posted January 11, 2014 http://www.sfvictoriana.com/ Quote Link to comment Share on other sites More sharing options...
Chad Fabry Posted January 11, 2014 Author Report Share Posted January 11, 2014 Don't know how strict you are on restoring, but I'd substitute something I could get done. You and my wife. Quote Link to comment Share on other sites More sharing options...
Chad Fabry Posted January 11, 2014 Author Report Share Posted January 11, 2014 I don't have an answer, unless you could have it made with a 3d printer; but if Les ever organizes a TIG road show I vote for a stop at Chad's House. Hopefully, things will be done enough for a clam-bake this fall. Quote Link to comment Share on other sites More sharing options...
Chad Fabry Posted January 11, 2014 Author Report Share Posted January 11, 2014 Thanks, David. I found that company a few days ago, it's on my "fall back" list to contact. I was hoping to find something a tad closer to home. Quote Link to comment Share on other sites More sharing options...
Bryan Posted January 12, 2014 Report Share Posted January 12, 2014 Have you tried reaching out to a plaster restoration company? They should be able to take your original piece, make a mold and cast new. I have never seen this personally done; however, have spoke with various contractors over the years, and monitored there progress on historic restorication projects. Quote Link to comment Share on other sites More sharing options...
Bill Kibbel Posted January 12, 2014 Report Share Posted January 12, 2014 It's either Cast Design or Castle Design. They're in Alabama and produce hundreds of plaster mouldings. Expert mouldmaker Thayer Smith of Downingtown, PA creates very accurate moulds for reproducing any plaster ornamentation. Quote Link to comment Share on other sites More sharing options...
Bill Kibbel Posted January 12, 2014 Report Share Posted January 12, 2014 Here they are: http://www.castledesign.com/pages/about-us.html http://www.traditional-building.com/bro ... ster.shtml Quote Link to comment Share on other sites More sharing options...
Jim Katen Posted January 12, 2014 Report Share Posted January 12, 2014 We used to make stuff like that all the time when I used to do scene construction in regional theatre. We'd typically use a bit of an original, like what you've got, as a general inspiration. Our painter would sculpt the necessary bits, usually starting with small, appropriately shaped tiny objects and enhancing them with bondo. After each pattern was complete, we'd make rubber casts of each one and then assign an apprentice to start casting them. After making a few buckets' worth of each pattern, we'd glue them onto the milled wood substrate. It being theatre, we usually then went about distressing them (whomping the shit out of them) to give them character. Most well-funded regional theatres have people who can do this kind of thing with one hand tied behind their back and they're used to working for slave wages. There's often a lull in their work schedules in the spring. Quote Link to comment Share on other sites More sharing options...
John Kogel Posted January 12, 2014 Report Share Posted January 12, 2014 Yeah, Chad. Can't you make your own with epoxy and flour? Add another year or two to the project. [] All the instructions for plaster casting are on this page: http://www.sfvictoriana.com/casting.htm I think you could lay a strip of wood in the mold for a backer? Quote Link to comment Share on other sites More sharing options...
randynavarro Posted January 13, 2014 Report Share Posted January 13, 2014 They're probably too expensive, but you can try: dillonworks.com. Quote Link to comment Share on other sites More sharing options...
BADAIR Posted January 14, 2014 Report Share Posted January 14, 2014 why not make a mold & cast your own https://www.google.com/search?q=alginat ... =firefox-a Quote Link to comment Share on other sites More sharing options...
Chad Fabry Posted January 15, 2014 Author Report Share Posted January 15, 2014 After researching the topic and visiting all the links you guys supplied, it became apparent that I couldn't afford to pay $30 a foot plus shipping for picture rail. I'd break into a sweat for every miter. After I decided it was just too expensive, I was still chatting with A. Thayer Smith III who owns a plaster company of the same name, (one of the links Bill provided). After a few minutes, Thayer offered another choice; he'd clean up my 18 inch section of good molding, re-detail the relief and piece together a seven or eight foot mold and mother. Additionally, he offered to give me a lesson on applying the casting to a wooden molding so we can have a functional picture rail. It still isn't cheap considering we have a couple hundred feet to do but it will bring costs down to about 5 bucks a foot and that'll take the angst out of the miters. My wife likes the Lancaster area, so it wasn't a hard sell; I expect we'll spend more on quilts and rugs than I will on the mold and the lesson. Thanks to everyone for the helpful suggestions. Quote Link to comment Share on other sites More sharing options...
hausdok Posted January 16, 2014 Report Share Posted January 16, 2014 Write an article for Old House Journal when you get done, Chad. ONE TEAM - ONE FIGHT!!! Mike Quote Link to comment Share on other sites More sharing options...
