Rob Amaral
    1,233
Everything posted by Rob Amaral
  1. wow.. that is troubling..
  2. As acts as an insulation-baffle... (the fire-stop)... definitely bring this up..
  3. Kibble has it.. Italianate.
  4. I say there is " an intolerable odor of some kind' at such and such and for them to get estimates for costs to remove it that may include refinishing of interior surfaces or removal/replacement of them.. " Something like that.. Then I'd just look at one of the clients or realtor and ask them, 'what does it smell like to you.. ? " They answer.. and their answers go in the report. "Client stated it smelled like body odor'..
  5. Yes... I've seen exactly that... I simply recommend that upgrade to a modern system for the obvious reasons..
  6. The problem is the NPMA-33 form 'comment' that Neal Lewis mentioned.. it's out there.. in print and tends to be the final word in a RE transaction.. On the other hand, Bill Kibble is correct.. for an 'owned property not under a transaction' process.. It depends on the situation..
  7. Lookin at my 9 yr old American WH here in the office.. .. not one issue.. I believe Mike is right.. it's multiple things.. probably highest is water quality and amount of usage.. I'd say a certain amount of 'less' use, more problems.. wouldn't you?
  8. I'd be replacing it 100%...and anything under it that was damaged (if wood).. These can hump up in major way ...
  9. Ran into the Nest recently.. pretty nice.. got the hang of it pretty quickly...Luxury condo in Boston..
  10. How about a 'box of 'brancircitoni'? This is where you go 'click.. this picture will say it better than I can in the report.. " Just show it to a good electrician, OK? "
  11. Is is possible the furnace(s) are too big for the space being heated?
  12. I had one where I met the suspected killer AT the house.... I'm serious.. very weird, creepy and I have to leave it at that! .. Everybody already knew and I just did my job.... I never found out what happened afterward.. weird cloudy grey day.. eeech..
  13. I'd guess 1960 era.. How old is the house?
  14. Hydro-air is the term used by the HVAC guys..
  15. Full price, full inspection.. 'don't assume anything'... and 'your time is money.. '
  16. very cold water would also be part of the equation.. right? Was it a community well?
  17. bill k is correct (as usual).
  18. I dunno.. I wouldn't be pulling outlets out and taking wire-nuts off my man.. You are 'disassembling the system' without permission of the owner.. (Or did they let you? )
  19. Richard, I call that the "Bronzed Baby Shoe Car" How is the pickup on that little thing? They look like a blast to drive..
  20. 32' ladder on conventional alum American van rack... two bungees per post.. 3 posts.. (2 on side, one at rear) and a lockable cable type system (bike-lock with cylinder lock). Change the bungees when they need it and you should be fine.. Not a problem in 18 yrs..Those latch sytems are not necessary.. Next van will probably have the swing-it-down thing ...Maybe going with a Transit connect... i dunno.. I like my E150...it's better to be sitting higher in this traffic.. Check out the nice parking job.. (North End of Boston) After a while.. you get used to this malarkey.. Download Attachment: VAN NORTH END.JPG 120.34 KB
  21. I frequently tell folks exactly how I think something should be repaired. I also warn them of what others will try to sell them. That is very good procedure BK.. I too tell them 'what others might say'.. That goes for a lot of things like chimneys and so forth.. If you give them the heads-ups, you've provided them a major service..
  22. 8 hours for how big?
  23. Can you say "Maintenance Headache" ? Fun stuff...
  24. Seen those.. I don't pull fuse blocks anymore.. That bakelite stuff is kind of brittle and every once in a while.. you see them broken.. I used to.. but I don't want one breaking on my watch...
  25. We see a lot of that type of house around Lexington/Concord/Lincoln MA..
