Greg Booth
    259
Everything posted by Greg Booth
  1. ..........that would be the blue plastic tarps seen everywhere?[]
  2. ..........sure - an attorney, paired with anyone, can argue with anyone, about anything, anywhere, even in court - as long as someone pays him. ......Greg.
  3. .........all HUD codes are shipped with the lockouts along with signage to warn about filling the tank before energizing.......Greg.
  4. hmmmm.......good question?
  5. ............if the home was in your area, it would just be for winter egress! Not this winter though............Greg
  6. Convienient to sit on the drywall bucket and tinker with thr load-center.
  7. There are also several variants on this theme using "plastic" cell material Greg
  8. Safe and Happy New Year to all................Greg.
  9. My business is located in NE Steuben, on the border with Yates County (where I live). Most of my work is in these counties with Yates being one of the smallest and Steuben one of the largest in NY. Towns in Yates seem to have the strictest (best) permit control while towns in Steuben are pretty "relaxed".
  10. ..............why? Greg Because...... Nolan posted some pictures I've never seen before and learned from. Digging it back up for review ain't a bad thing. ...........not questioning the issue of bringing back old threads..........I was wondering why the concern with Pex stub-outs Greg
  11. ..............why? Greg
  12. ...........yeah, what you said. .........Greg
  13. ..........as long as they had her on a plane, they shoudda just flown out over the lake and dumped her there.[:-crazy] .........Greg.
  14. The problem really resides with the retailer/dealer--say that quick and it sounds a lot like realtor. And they are a lot alike-to suck the most money out of the deal they cheap-out on the biggest expense which is the installation. Just like good and bad HIs, there are good and bad installers. Manufactured home (nee trailer) installers are now licensed by NY department of state, and this has raised the performance level to some extent-sorta like licensing HIs[:-dunce]. In fact, when an installer applies his seal to a manufactured home, he is certifying the propriety of every system in the home--inluding the on-site work of the electrical service, the gas service, the water service, the foundation structure and on and on. This is backed up by a cash bond for rework that is directly accessible to the NYS DOS. There is no certification needed for installers working on modular homes!! The AHJ needs to get seriously involved in all of these installs in order to improve the conditions you describe. Of course, the majority of my inspection work is a direct result of consumer complaint activity--so let's not fix too quickly[:-tong2]
  15. Isn't that the "Pioneer Series"- easy bake oven?[] ........Greg
  16. I've seen several examples of gas grill siding issues and it has always been at about the height of grill, up-never down to the floor. It usually appears to be about grill-width (30 or so inches), and the siding droops or sags. I believe your'e on the right track............ .......Greg
  17. Back in the day, when I worked in the Hospital facilities field, DOH surveyors considered multi basin sinks, such as double and triple commercial kitchen sinks as single fixtures. ......Greg
  18. .........same here, with footers below frost line. ......Greg
  19. I agree with Marc ........Greg
  20. .............probably time for a replacement[:-tong2] .........Greg
  21. Propane systems in my region are nearly always copper......... if the installation is done by the gas supplier. Natural is always black pipe.[] ............Greg
  22. In my area, it's routine to see electric water heaters with enough crud in them to bury the lower element. The drain valve is almost always plugged--compressed air must be used to encourage water drainage when replacing the tank. .........Greg.
  23. "technically" correct, but practically........... a home served by a (sub)panel with a 200A breaker, fed from a 100A breaker at a meter bank..........that 200A breaker will be considered the "main". I see this exact set-up in manufactured home communities often. The community operator generally will not allow "their" breaker to be used as a disconnect by the homeowner/service folks. ..........Greg
