Jeff Beck Posted April 2, 2009 Report Posted April 2, 2009 Is there an advantage to having a closed valley versus an open valley, or vice verse? I've seen open copper valleys with slate and galvanized open flashing with just about everything else but never have really known why one style was preferred over the other. Jeff Beck Foresight Inspection Service LLC
randynavarro Posted April 2, 2009 Report Posted April 2, 2009 By "closed" I'll assume you mean a woven valley or a closed cut valley? I would think closed valleys are simply cheaper. No metal is required and not as many shingles need to be cut unlike a metal valley where each shingle needs cutting to line it. Other than that, if done correctly I would say that either closed or open peform equally as well if the right materials are used. Some purists might come along though, and completely disagree with that statement.
Chad Fabry Posted April 3, 2009 Report Posted April 3, 2009 I almost always weave or install a closed cut valley over aluminum. I know it's overkill but when I install the aluminum I staple one side then use a roll of felt to shape the valley as I staple the other side (staple=whacker tacker). The gentle radius lets the shingles make the transition from plane to plane better and keeps the laminations from separating. Metal valleys shed snow and debris better than the shingled over varieties.
Jim Katen Posted April 3, 2009 Report Posted April 3, 2009 Chad Fabry said: I almost always weave or install a closed cut valley over aluminum. I know it's overkill but when I install the aluminum I staple one side then use a roll of felt to shape the valley as I staple the other side (staple=whacker tacker). The gentle radius lets the shingles make the transition from plane to plane better and keeps the laminations from separating. Hey, I used to use that same technique. (Well, except I wasn't anal enough to use a roll of felt, I just set the coil stock with a nice fair curve to it and tacked it in place.) When I build my present house in '91, I showed that technique to the roofer -- he'd never seen it before. I know he thought I was nuts, but he was nice enough to use the technique throughout. Times change though. When I built an addition a few years ago, the roofer asked, "You want me to do anything special with the valleys?" I just said, "Do what it says on the package and make sure they don't leak." I'm getting more & more lazy as I age -- even when all I have to do is tell other people what to do. - Jim Katen, Oregon
Bill Kibbel Posted April 3, 2009 Report Posted April 3, 2009 When doing valleys on my own homes, it's open with 24" wide, 26-gauge galvanized steel with a 1.5" high center rib. I then coat it with Acrymax, pigmented to match an historic paint color.
kurt Posted April 3, 2009 Report Posted April 3, 2009 Closed cut is the easiest and looks just fine imho. Never liked weaves for some reason. If you're using shake, tile, or stone, nothing looks nicer than open w/ridged metal like Kibbel just described. WR Grace under everything makes any valley work longer than anyone will care.
Richard Moore Posted April 3, 2009 Report Posted April 3, 2009 inspecthistoric said: A swept valley is the prettiest. ...and at the other end of the scale there's this from today's inspection. Click to Enlarge 112.03 KB Click to Enlarge 157.91 KB Click to Enlarge 139.72 KB Evidently, you can do it anyway you want as long as you caulk between every tab! [:-propell
Jim Katen Posted April 3, 2009 Report Posted April 3, 2009 inspecthistoric said: A swept valley is the prettiest. The third course up on the left side is uneven. I think he should redo it. - Jim Katen, Oregon
Jeremy Posted April 3, 2009 Report Posted April 3, 2009 I agree with Kurt and Bill. The swept valley is the prettiest, but for those who don't have that privelege I like the clean line of a well cut closed cut valley. Jim, that swept valley may look alright to you in a couple years.
Kyle Kubs Posted April 3, 2009 Report Posted April 3, 2009 As stated above, either can work fine given due attention to the details. Personally I think open valley's belong on certain style homes and are more appropriate for a steeper pitch using composite shingles, as when the pitch increases the angle between the two planes that the shingle must be bent into becomes more acute. This goes double today with the laminated shingles. On the other side of that coin, use an open valley on a lower pitch roof and you can have more danger of falling tree branches poking holes right through the sheet metal, which I find often.
Kyle Kubs Posted April 3, 2009 Report Posted April 3, 2009 Jim Katen said: inspecthistoric said: A swept valley is the prettiest. The third course up on the left side is uneven. I think he should redo it. - Jim Katen, Oregon To my eye, it looks like more then just the third course. The angle of the picture may be skewing things a lot from what they really are but it looks like the arcs, angles & exposure are running off. Click to Enlarge 48.79 KB I would starve to death doing that kind of work. I find it impossible to keep my furnituremaker's blood from running the show. Any of my friends seeing me up on that roof would instantly say, "check his tool belt, bet ya he's got a dial caliper in there somewhere" It's not my fault really, I have this geometrical obsession that puts me into the deranged category of anal where that stuff is involved.
kurt Posted April 3, 2009 Report Posted April 3, 2009 Never had the pleasure of seeing a swept valley. It's all metal and open valleys around here. What's the roofing style on old English cottages where it looks like there's about 30 layers of shingles that are globbed into a rolling wavelike appearance? My memory for terminology is failing.......
Kyle Kubs Posted April 3, 2009 Report Posted April 3, 2009 kurt said: Never had the pleasure of seeing a swept valley. It's all metal and open valleys around here. What's the roofing style on old English cottages where it looks like there's about 30 layers of shingles that are globbed into a rolling wavelike appearance? My memory for terminology is failing....... I know I'm going to be corrected on this, at the very least for the spelling, but I think your talking about Cotswold...
Rocon Posted April 3, 2009 Report Posted April 3, 2009 Monier (in their current ER report) suggests open valleys where you may have alot of organic material falling on the roof. It is a maintenance issue, If you have a closed valley and get debris in it you will have more lateral water movement. Even if you have batten extensions for the slate or tile roofing you will have more of a tendency to overtop the hemmed edge. That is why I typically insist on a valley pan with three ribs. That way debris stays in the cener rib and the two secondary troughs will give the water a clear path.
Les Posted April 3, 2009 Report Posted April 3, 2009 only valley I know about is the "Big Valley" with Barbara Stanwyck.
Ken Meyer Posted April 3, 2009 Report Posted April 3, 2009 kurt said: Never had the pleasure of seeing a swept valley. It's all metal and open valleys around here. What's the roofing style on old English cottages where it looks like there's about 30 layers of shingles that are globbed into a rolling wavelike appearance? My memory for terminology is failing....... When in England some years ago, I heard "wimbly wambly" used to describe something that is wavy. Could be "wombly" though.
Bill Kibbel Posted April 4, 2009 Report Posted April 4, 2009 Quote What's the roofing style on old English cottages where it looks like there's about 30 layers of shingles that are globbed into a rolling wavelike appearance?I don't know of a name of the style other than what I've read in advertisements guides from the first quarter of the last century - "false thatch". The shingles were steam bent to curl over the gable ends and butts cut at angles to create undulating course lines with very little exposure. Quote I think your talking about Cotswold... Cotswold Cottage is a style of American home that was built during the first quarter of the last century. I think many seem to be an insult to the actual period homes throughout the Cotswolds in central England.
Garet Posted April 16, 2009 Report Posted April 16, 2009 Open or woven doesn't really matter, as long as you install proper valley cap shingles on top. Click to Enlarge 74.24 KB
Jerry Simon Posted April 16, 2009 Report Posted April 16, 2009 Garet said: Open or woven doesn't really matter, as long as you install proper valley cap shingles on top. Click to Enlarge 74.24 KB That's one of the funniest construction pictures I've ever seen. Like those weird pictures...the more you stare, the more you see you can't believe.
